FB-B Disk opener ?
Chuck McDonald
03-26-2007 13:30:32
Howdy,
I was working on my FB-B drill (dual disk openers) last night and began the process of putting the disks back on. Much to my dismay, with them tightened up there was about 1/4-1/2" of slop betweeen the leading edges of the disks. What a pile of junk! The way the disks are made is they have a cover with a short bolt that appears to be riveted to the disk blade. Is this correct? Anyone rebuilt these before to know what I am up aginst?
It had only one of the two disks on it when I picked it up....I think I know why! They were just using it as a single opener drill since it was so worn!
Thanks
Chuck
Glen in TX
03-26-2007 18:31:56
 Re: FB-B Disk opener ? in reply to Chuck McDonald, 03-26-2007 13:30:32
Thats why single disk was always more popular here as double disk openers have always taken more to maintain and when anything is too worn they don't work as well. The shoe or mounting hole wears out on them. You can always just take the two carriage bolts loose on front and change the whole opener over to single disk, hoe type, or later double disk style if you want from used or salvage parts off other drills. Salvage yards adeptr.com (parts then state). Burrells JD may have openers ready to go you can buy also.
