JD 400 Starter
James Pearson
03-26-2007 09:30:16
The solenoid on the starter has gone bad, my question is do i have to find a John Deere solenoid or is a common item somewhere?
Thanks JP
Bob
03-26-2007 12:55:36
 Re: JD 400 Starter in reply to James Pearson, 03-26-2007 09:30:16
The solenoid isn't even priced too badly at DEERE; @ a little over $25.00.
jdemaris
03-26-2007 11:13:02
JD400 is just the yellow-version of the green 2020. Takes the same Delco solenoid as most older GM cars and trucks. Go to NAPA and buy a solenoid for a 86 Chevy truck or car with a 350 gas or 6.2 diesel - and the solenoid will be the same.
Mike M
03-26-2007 10:10:44
400 tractor or lawn mower ? I guess either way a local starter shop or NAPA should be able to fix you up. You shouldn't need a JD dealer on that item. Even though the dealer may have a competive price. May be worth a check if you have a dealer close by. I know they are getting fewer and farther between.
