Courtland: Here is how I computed the length of that pipe for my application: I had some 2-inch Sch 40 PVC pipe available and also an adapter from slip-to-thread (female). From there I constructed a model of what would work. You have to be right on this one because of how far forward the fuel tank extends. As for space between the pipes, start by going to the JD-H Restoration Site, and one-click on HOSE CHART. There is some instruction on how to use the chart. You will find the upper hose call-out (B406R) to be 6-inches long so you can tolerate at least a 2-inch gap between the two pipe sections. The lower hoses (2 each B402R) are called-out to be 4-inches long and so down there, you are should a gap limited to about one inch in each application. Be advised, the stick hose inside diameter you will need is 2-3/8-inches for both upper and lower hoses -- available but not cheap at NAPA stores. As it turns out, I ended up buying a 2-inch (galvanized steel) pipe nipple that was a foot long, and then cut the pipe at the 4-inch-from-one-end mark. This provided me with a new piece for both top and bottom tanks. At JDHPUBS, our most important product is new/old designs, or innovation! (PatB)
