4020 Parking brake question
Ralph Wilks
03-26-2007 06:33:42
I'm making progress on my parking brake problem. After doing some investigating this weekend I found that the parking brake pawl works but it appears that the cable is not pulling it up far enough to engage it. I don't know exactly how the whole thing is supposed to work with the levers but it appears that when you put the tractor in park, it hits the lever that has a spring on the other end and the spring is attached to the lever that has the cable. So the spring actually pulls up on the lever with the cable to engage the parking pawl. The lever that has the cable on it is shorter than the spring lever so nothing hits it when I put it in gear. Seems weird that that lever with the spring does all the work.
It looks like everything is adjusted about as far as it can go. I unhooked the cable and pulled it back out under the dash so I could get at it and put WD40 down the cable and worked it by hand to try and make the cable work smoother. Still seems to catch in one place. I could hear the parking pawl go in and out.
I have ordered a new cable and springs in hopes that it will cure the problem but after talking with the dealer they were unable to tell me if the way it is working is correct. It looks like the lever that is attached to the cable is shorter on the end closest to the seat and that when it is put into park nothing is actually suppose to hit it and that only the lever with the spring is supposed to make contact. I can't tell if the lever with the cable is broke off or what it is rusty and appears if may have been welded at one time but don't know for sure.
Also, can anyone tell me if the other end of the parking cable is outside of the transmission or do I need to take up the floor board and cover to change the cable. I opened up the battery box and try to see back in there but it was covered with dirt.
Thanks for your help in advance. I love this forum. It's a wealth of info.
Sorry about being so wordy but it is hard to explain.
Mike w J
03-26-2007 16:59:55
 Re: 4020 Parking brake question in reply to Ralph Wilks, 03-26-2007 06:33:42
Part no. 7 is meant to hit 28 part no. 11 gets wore and causes to much play in lever. When you put the tractor in park try to push down on the lever and pull it tight to the bottem of the park slot it semms to help on our 3020 but if you adjust part no 7 longer make sure it don't partially ingage park while in low gear. I have seen part no. 29 on a tractor that had a wire threw it and twisted so that the wire pulled in to park instead of spring It seemed to work ok.
Ralph Wilks
03-27-2007 03:58:52
 Re: 4020 Parking brake question in reply to Mike w J, 03-26-2007 16:59:55
Thanks for the reply Mike. Right now my PN# 7 comes down and hits PN# 26 so that the spring is the only thing that is pulling up the cable. I ordered a new cable because mine is sticking. I checked on a new PN# 28 but it is $185. I thought for that price I could weld on a new piece on the end if it was suppose to stick out that far for the PN# 7 to hit it. I wasn't sure if it was and could not find out from the dealer if it did.
I thought about using a small rod and making a linkage to hook PN# 28 and PN# 26 together instead of the spring.
Mike w J
03-27-2007 06:00:53
 Re: 4020 Parking brake question in reply to Ralph Wilks, 03-27-2007 03:58:52
The reason they use a spring instead of a rod is sometimes when you pull into park the park paw lands on top of the gear tooth instead of down in the gear On ours if you pull lever down and let off of the brake it will move just enough to go into park. The cable may just correct your problem .
Ralph Wilks
03-27-2007 07:17:30
 Re: 4020 Parking brake question in reply to Mike w J , 03-27-2007 06:00:53
That's kinda what I thought. I noticed that when I left the dash cover off and pulled up on the cable while sitting on the tractor that I had to let off the brake a little for the pawl to settle in.
Have you had problems with yours slipping out of park??
Mike w J
03-27-2007 18:25:59
 Re: 4020 Parking brake question in reply to Ralph Wilks, 03-27-2007 07:17:30
It has never jumped out of park after it was in but if your cable is sticky maybe its not going in all the way . if you can slide the cable ahead in the clamp a little to make sure it goes in all the way. Our 3020 is a gas the worst part of the whole tractor but it don't have a right side battery so its real easy to get at that cable . if that cable is unhooked on the bottem end you can move it in to park by hand. to see how much it needs to travel to be in and out of park .Then you can adjust your cable acordingly.
cable
03-26-2007 13:33:38
Loosen the nut that is on the clamp(number 40). Then slide the cable outer housing to the front of the tractor. You will probably not move it more than 1/4 to 1/2 of an inch. Then retighten the clamps and it should go back to working. Over a period of time the clamps loosen and allow the housing to move towards the back of the tractor and it will not engage the lock
Ralph Wilks
03-26-2007 15:26:49
 Re: 4020 Parking brake question in reply to cable, 03-26-2007 13:33:38
Cable, Won't I need to loosen all of the clamps 40 and 43 to move the cable foward?
I'll give it a try. Do you know about the question I have as to if the spring lever is suppose to pull up the lever with the cable, rather than pushing down on the lever with the cable directly?
Bob
03-26-2007 07:09:46
third party image
"Also, can anyone tell me if the other end of the parking cable is outside of the transmission or do I need to take up the floor board and cover to change the cable."
The lower end of the cable is EXTERNAL to the transmission.
Ralph Wilks
03-26-2007 07:16:12
 Re: 4020 Parking brake question in reply to Bob, 03-26-2007 07:09:46
Bob, In your picture, do you know if PN #7 is meant to hit PN #28 or only PN #26?
Mike M
03-26-2007 07:51:32
 Re: 4020 Parking brake question in reply to Ralph Wilks, 03-26-2007 07:16:12
If you got that older style with # 26 and #28 I hope you have better luck getting yours to work than I had. Don't trust it on a hill ! And when working/fiddling on it DON'T stand on the ground with the engine running or else it will run you over !
Ralph Wilks
03-26-2007 08:58:56
 Re: 4020 Parking brake question in reply to Mike M, 03-26-2007 07:51:32
Yep, I know better to work on stuff like that while it's running. As far as not trusting it, I kinda figured that. My boys have Case tractors on their farm that use a parking brake similar to this and they have had it jump out twice on them.
Mike M
03-26-2007 09:54:35
 Re: 4020 Parking brake question in reply to Ralph Wilks, 03-26-2007 08:58:56
I kinda thought/hoped you did ,but it never hurts to give a heads up about saftey problems. It's sometimes hard to keep saftey in the forefront of our minds. All it takes is one time.
