2520 JD Dies
Bobl1958
03-25-2007 16:41:07
Don't know what to make of this. My 2520 gas has started to die when I put down pressure on the bucket. I was backdragging my drive and all of a sudden every time I dropped the bucket and put pressure down on it the tractor died like the key was shut off. If I let the pressure off, it would not take off again. I could start it right back up, but it would die the next time I did the same thing. Otherwise, it seems to run alright. The loader is plumbed into one of the back cv,s. I know it's not much to go on, but any ideas? Thanks-Bob
buickanddeere
03-25-2007 18:59:36
 Re: 2520 JD Dies in reply to Bobl1958, 03-25-2007 16:41:07
Carb float. If you get the ported trans filter housing for the loader return line. And supply the loader direct off the high pressure line between the brakes and the remote valve. You will wonder how you ever got by with the loader plugged into the cvs's.
