B flywheel removeal
Ben Lanpi
03-25-2007 14:38:11
Need to fix an oil leak behind the flywheel on my JD B 1944.Manual said I need a JD wrench to remove the flywheel. Is this some thing I need to get or will a diff tool work.
Thank-you Ben
johns48jdb
03-25-2007 14:56:35
 Re: B flywheel removeal in reply to Ben Lanpi, 03-25-2007 14:38:11
i don't remember it taking any special wrench on my 48 b. i'd use anything you can get that will fit. seems like i remember having to use a cheater bar on my wrench to get it loose. that was in 99 so i forget. boy, this growing old is so much fun!
F-I-T
03-25-2007 15:30:14
 Re: B flywheel removal in reply to johns48jdb, 03-25-2007 14:56:35
third party image
John, the '48 has the bolts on the outside of the flywheel and the '44 has them on the backside. A '48 would use a suppplied wrench like #7, or just common tools. To reach the back side bolts takes a bit more trouble.
There are some special wrenches that were supplied with the tractor when new that were used to adjust the wheel tread and for use on the flywheel bolts. I bought my last one on Ebay, though others have fabricated them from bar stock and then welding an appropriate socket on the end.
Frank
