JD 60 engine/transmission oil
R. Stringer
03-25-2007 09:24:31
Does the engine share oil with the transmission or are they separate? If they are separate how many qts does the transmission take and where do i check the level?
R. Stringer
03-26-2007 17:24:36
 Re: JD 60 engine/transmission oil in reply to R. Stringer, 03-25-2007 09:24:31
Thanks all. Thats exactly what i needed to know. Now all i need to do is go buy more oil, buying oil these days is always fun, hahaha.
Larry in WNY
03-26-2007 09:12:57
The transmission oil IS separate from the engine oil. For the engine use 10W30, 10W40 or 15W40. Engine oil filler cap is on top of crankcase near the belt pulley. There is a plug to screw out, near the serial number plate, and when oil runs out you have the right amount.
The transmission can use GL1 140W or 85W140 multi grade gear oil. The transmission filler is on the rear end near the drawbar. The first reduction gear cover needs oil too. I think there is a plug near the cover for that one.
Larry
Kemper
03-26-2007 05:55:47
No they are not seperate. It will hold 6 gallons of 90wt oil. plug is on right side of rear end case.
DSK
03-25-2007 16:45:11
The transmission holds 24 qts of 80W90 or similar weight gear oil. It gets filled to the top of the check plug located on the right side of the rear end cover. An operators manual will tell you all about it & will cost less than the 6 gallons of oil, and if you're not familiar with the tractor you'll find it useful quite often.
