3020 gear shift
dynaflow
03-25-2007 05:53:35
On the side console 3020 diesel what is the difference between the ones with a shift lever that has one bend and one that has a lever with two bends. Where would I find information on how to read the model number ahead of the serial number to tell what it means.
Thanks David B
Glen in TX
03-25-2007 17:28:02
 Re: 3020 gear shift in reply to dynaflow, 03-25-2007 05:53:35
Probably find the serial number change on levers in parts catalog?
MSM
03-25-2007 06:36:58
Not alot of difference between the 2. Crooked shift came the same time they added a dimmer switch and single headlites,about mid run 1971.
sodly
03-25-2007 18:27:34
 Re: 3020 gear shift in reply to MSM, 03-25-2007 06:36:58
I was not aware that single headlights were a standard feature after 1971. Are you sure about that? Were dual headlights optional after that? Thanks.
