630 vs 5x14 plow..??
BushogPapa
03-24-2007 22:42:04
Any chance the 630 might pull it..?? New 15.5x38 tires and 3 sets of weights. Strong, fresh engine...
I guess I can drop one bottom if I have to..
Found this and it is too good a deal to pass up.. Only gonna use it on "Plow Days" probably..
Thanks....! Ron.
MLD
04-01-2007 10:11:59
 Re: 630 vs 5x14 plow..?? in reply to BushogPapa, 03-24-2007 22:42:04
Sounds ike too much!!! I've got 3-14's for my 620. They work good behind it in our soil. The guy I got the plow from had it behind a 520. He had very sandy soil so the 520 could pull it but I wouldn't try it at our place.
BushogPapa
03-26-2007 12:13:31
I pulled a mounted 3x14" last year, 7" deep and it was perplexing...!! Not enough to allow the "Load and Depth control" work, without it raising the plow every time it attempted to transfer weight..at the 1st hole for minimum transfer.. In third, I had to run at less than 1/2 throttle or I was travelling too fast, with the large rocks I was skimming over...!! The 630 handled it real well in third, with reduced throttle, even in the Black Ground, AND Alfalfa... I know, it was sold as a "4-Plow tractor", but JD wouldn't Guarantee it to pull 4-14"...!! AC DID Guarantee the WD-45 to pull one, and that is what we used....TWO of them...8 Bottoms with 84 Horse Power..not too Bad..!! I can drop a bottom for the 630, and/or leave it alone, for the 720 Diesel... Sure will look Great behing either one of them, too..!! Thanks for all the Great comments....!!!! Ron.
buickanddeere
03-25-2007 19:07:21
Two bottoms too many.If she can't pull it in 3rd gear it's too much drawbar load.
HAPPY DEERE
03-25-2007 13:06:30
depends on the soil ive seen early b pull 3 bottoms in sandy soil in 2 or 3 gear and have no problem but if your in black gumbo then i wouldnt try it
Farmboy169
03-25-2007 08:39:32
I say the same as Handsome Jim. Last year during "Plow Down Days" we had 2-14's behind an AW and 3-14's behind a 620. The soil was black and heavy. The tractors seemed to be paired up about right, but after a few "adult beverages" the tractors seemed to have alot more power!! LOL!!!
fixerupper
03-25-2007 07:49:34
I assume it's a pull type. If you are in really sandy soil it might have enough power in 2nd or maybe 3rd gear for awhile until the radiator gets hot. We pulled a mounted 4x14's with a 630 for years in moderately black soil and it was really too much plow unless we hit a sandy spot and then it would more or less loaf along.Sometimes I would shift up to fourth in the sand and feel the wind in my face for about fifteen seconds, the I'd be in the black stuff again and it'd be back down to 2nd or 3rd.(don't tell dad about this) We usually were in 2nd gear in the fall and possibly 3rd in the spring. In alfalfa it was 1st or 2nd and sometimes we would have to drop a bottom. Jim
machinery-man
03-25-2007 07:03:03
Had a friend that claimed his 520 had so much "power" that he could not hold the clutch while pulling 3 14" plows. I advised him that it wasn't power but that he was abusing the clutch and tractor as the stress point would be at the clutch as well as rest of drive trail. 2 14" were recommended and I would suggest that 3 14" or 16" is right for your tractor....what good or point made to lug and bog it to death, I can assure you that you wan't get work done faster as you'll be in lower gears fighting the plow. Also what about the weight transfer and safety. Recommend you get 3 14"s you'll be much happier...
Handsome Jim
03-25-2007 06:34:27
We pulled 3 14s with our 620 and 60. that was in black 'gumbo' though.
jdjerry
03-25-2007 05:43:42
We had a neighbor that ruined a new 720 in one year pulling 5-16 plow.
Mike M
03-25-2007 04:39:24
It all depends on the ground. I pulled 3x14 with a late B in good conditions before so you may have a chance in good conditions.
low budget
03-25-2007 04:08:41
Pulled a 3-16 mounted plow with my 620, motor is whipped, but handled it OK. 4-14s would be a good match for your 630, people may laugh at 5-14s. I'd try it without an audience first. If it works you can impress people, if not its an excuse for a bigger tractor.
jhill52
03-25-2007 03:37:24
3X16 plow is all a 630 will want to handle in most conditions.
Dan in Ohio
03-25-2007 03:07:18
Ron, We had a 630 on our farm when I grew up. We had a 3x16 mounted plow matched with that tractor. I am afraid some will get a laugh at you trying to pull a 5x14. Although I would not be afraid of a 4x14 pull type plow in light soil.
