JD 40 Carb
buster 2007
03-24-2007 20:47:52
Trying to get a 40s running. Problem is it will only run if the choke is on all the way. Any ideas?
tstex
03-25-2007 06:25:57
 Re: JD 40 Carb in reply to buster 2007, 03-24-2007 20:47:52
Obviously, you have a fuel restriction. Start with the basics:
Adjust the carb settings to increase the fuel input. if that does not work, then check your fuel flow from the tank to the valve on the bottom of the carb...if that is good, then it is time to pull the carb and perform an overhaul.
Couple of questions - how long as it been running where you had to have the choke pulled all the way?
tstex
Buster 2007
03-25-2007 18:12:59
 Re: JD 40 Carb in reply to tstex, 03-25-2007 06:25:57
This is the initial startup. This was wife's grandfathers tractor Been sitting out for years and engine was locked up.Restoration was started by her uncle but he did not have time to do it so he gave it to me.He told me that the carb was rebuilt and it was clean. It may be the adjustment screws on the top and bowl are not set correctly.Anyone know the way to set these?
buickanddeere
03-24-2007 23:24:49
Which way are the idle and main screws turned?
CLTX
03-25-2007 10:10:41
 Re: JD 40 Carb in reply to buickanddeere, 03-24-2007 23:24:49
Tstex, did you get that tractor moved?
tstex
03-26-2007 05:12:40
 Re: JD 40 Carb in reply to CLTX, 03-25-2007 10:10:41
CLTX,
I am in the planning stage. I do not have to move it until mid April and wanted to do all my homework up front. Appreciate you asking.
regards,
tstex
