3-point on a 720 doesnt work need advice
pt756
03-24-2007 17:53:31
on our 720 the 3-point doesnt work,hasnt been used in a quite awhile, dont know much about that area, is it related to the hydraulic system where you hook up your remote cylinders to? is there a switch that you turn on the left side above the flywheel? also we only have the arms right next to the seat, will need linkage and sway bars, what is cost and is it available after market? also is it the same as a 520 and 620? thanks for any replies, first green one we have owned.
Dan in Ohio
03-24-2007 19:42:04
 Re: 3-point on a 720 doesnt work need advice in reply to pt756, 03-24-2007 17:53:31
You may have the hydraulics set to operate a remote cylinder, not the rockshaft. There is a metering screw on the left side of the valve housing that needs to turned out 2 full turns to operate the rockshaft. Check your hose connectors to see if they look the same, if not you may have a selector valve which may need adjusted. This can be confusing even when having all the manuals in front of you.
jhill52
03-25-2007 03:50:16
 Re: 3-point on a 720 doesnt work need advice in reply to Dan in Ohio, 03-24-2007 19:42:04
My 720 owners manual doesn't show that valve. I don think that is true of 720's. 50's 60's and 70's had that feature because the same lever is used to control both the rockshaft and the remotes.
CLW
03-24-2007 18:28:55
You must turn the pump on before starting the tractor. Otherwise it will grind if you try. Also you need some weight on the arms for them to come down. You may not have a problem, just not doing it right.
jhill52
03-24-2007 18:02:24
The same pump is used for both the 3pt and the remotes and is turned on down by the flywheel. The 720 uses different lift arms than the 520 and 620.
