Help cranking a 52 Deere 820!
Bill Perkins
03-24-2007 12:31:04
My Mom has a 1952 John Deere 820 Diesel I'm trying to crank. Let's just say there's no decals and no shift patterns left on this job. It was cranked by an uncle last month. I need to mow the grass, but have no idea as I haven't driven it since I was 15. Where the hell is the choke? Where is Reverse? I'm just pushing the clutch and hitting the starter and it's turning but it sounds like it needs a choke.
Help!
CLTX
03-24-2007 19:14:42
 Re: Help cranking a 52 Deere 820! in reply to Bill Perkins, 03-24-2007 12:31:04
Bill, the 820 wasn"t produced until 1957 and then only for two years. In 1952, the R was the only diesel built by John Deere. The 820 used a pony motor for strarting. You mentioned pushing on the clutch. Both the R and the 820 had a hand clutch. However, John Deere brought out a totally different version of the 820 in 1968 thru 1970. I expect that is what you are referring to. This was a three cylinder diesel tractor, which bore no resemblance to the original 820. I don"t know if it came in a gas version, as I"m not familiar with that tractor. Good luck. C. L.
flying belgian
03-24-2007 13:06:39
If it is a 1952 it is not an 820. If it is a diesel it has no choke. How old are you now so we can determine how long since you started it. Are you sure this is the same tractor you drove at age 15?
Bill Perkins
03-24-2007 22:59:39
 Re: Help cranking a 52 Deere 820! in reply to flying belgian, 03-24-2007 13:06:39
Actually, I finally got it started. I'm positive it's an 820 but I guess I'm wrong about the year.
It turns out I hadn't flipped on the main electrical switch before pushing the crank button. I thought it was the lighting switch. Noting is labeled as the tractor has been repainted ages ago and all decals or labels are gone.
And no, now that I think about it, the one I drove when I was 15 had those two wobbly wheels in the center and the throttle on the column. I think that was a 1930's model. I guess my step-dad had replaced it sometime and didn't say anything about it. It was just in the same spot as always, so I assumed it was the same tractor.
flying belgian
03-25-2007 09:16:16
 Re: Help cranking a 52 Deere 820! in reply to Bill Perkins, 03-24-2007 22:59:39
Wow.
