'R' rear tire size
fixerupper
03-24-2007 06:28:41
The rear tires on my R are 18.4-34 and the rims appear to be the same age, or about the same age as the tractor. The literature I read only lists 14-34 or 15-34 as tire options and the decal on the battery box lists 14-34, 15-34, and 18-26. Could the tires on this tractor be a factory option that just isn't listed or were they possibly installed by the dealer? The serial number is 250 from the last one made, and it has export decals, but was bought new in North Dakota off the dealer's lot by my stepmom's dad. It's one of those situations where I wish I would have asked him while he was still alive.Jim
skip33652
03-24-2007 07:05:51
 Re: 'R' rear tire size in reply to fixerupper, 03-24-2007 06:28:41
18.4x34 replaced 15x34.
16.9x34 replaced 14x34
23.1x26 replaced 18x26
BLinWMi
03-24-2007 07:29:32
 agree in reply to skip33652, 03-24-2007 07:05:51
Skip is correct, these are 2 different measurements for the same tire from 2 different time periods. Similiar with tractors that listed 13x38s, the same actual tire today is 15.5x38. 12x38 are 14.9x38. same tire just different way manufacturer measures them today.
massey333
03-24-2007 13:51:58
 Re: agree in reply to BLinWMi, 03-24-2007 07:29:32
Try again,11-38=12.4-38,12-38=13.6-38,13-38=14.9-38,15.5-38s was a new size in 1958 or so.No offince meant but needed to be corrected.A 14.9-38 is a bigger tire then a 15.5-38.
BLinWMi
03-24-2007 16:16:13
 ? in reply to massey333, 03-24-2007 13:51:58
I had a list of current tire sizes and the old case sizes that they represented and have went from my list. guess it doesn't surprise me the list is off. But not sure how a 14.9x38 is a bigger tire than a 15.5x38.
johndear
03-25-2007 07:16:01
 Re: ? in reply to BLinWMi, 03-24-2007 16:16:13
Look at Firestones chart, a 14.9 - 38 is closer to a 16.9 -38 and is larger than a 15.5. The 15.5 is a "low profile" tire and a 14.9 is a taller tire, therefore, more rubber on the ground. That is what makes it a "bigger" tire.
Mike Aylward
03-24-2007 16:25:38
A 14.9-38 is a TALLER tire than a 15.5, but has a narrower tread width. The 14.9 puts a slightly larger footprint on the ground due to it"s larger diameter/circumference. Mike
fixerupper
03-24-2007 10:58:32
When was the change made? These tires have been on the tractor since 1966 or maybe before that. Jim
JMS/MN
03-24-2007 11:03:07
 Re: agree in reply to fixerupper, 03-24-2007 10:58:32
Old size marking went to new size marking about 50 years ago.
fixerupper
03-24-2007 17:58:51
 Re: agree in reply to JMS/MN, 03-24-2007 11:03:07
For some reason I had it in my head that the size change was sometime in the sixties. Shows how little I know about this. Thanks for setting me straight. When I got this tractor it had fluid in the rears plus three weights per side which would put it's weight at about 9500 pounds. Quite a lot of weight for a 50 horse tractor. It came from North Dakota where the soil is fairly loose so it probably needed the traction. I got rid of the fluid and here in Iowa it still has enough traction to pull the front end up when it's pulling 4-14's. Jim
