630 STARTER PROBLEMS
MJN in OH
03-23-2007 18:14:02
My starter will not stay engaged to the flywheel. Sometimes it will stay engaged and start the tractor. Other times it will turn over a little then starter gear will retract. It looks as if the drive gear pulses in and out. Starter was taken out gone through and cleaned up. I replaced the solenoid thinking this may be my problem but that did not work. Any help would be greatly apprieciated
Mckad
03-23-2007 19:15:34
 Re: 630 STARTER PROBLEMS in reply to MJN in OH, 03-23-2007 18:14:02
I had a similar problem on my 730 gas. I had the starter out and worked over in town, but it still acted the same. In the back of my IT manual it showed how to adjust the bendix out and what the measurement should be from the end of the starter. I adjusted the length of the arm that pushes the bendix . It is attatched to the selenoid. It cured the problem, and thats been about four years now.
F-I-T
03-23-2007 18:54:16
It really sounds as though the starter drive, or Bendix mechanism (the gear/spring/overrunning clutch device on the nose of the starter), is worn beyond limits. Once the O/R clutch gets too much wear in its ramps, the toggles can't grab and hold during cranking, so they slip and the engagement is lost. The gear retreats to save itself.
Many times a starter shop will only turn the commutator and install brushes and not look the drive over. It's a common NAPA item and pretty easy to install. I really think that's all you need, but I have been wrong before.
Frank-headin'-for-a-red-eye-flight-across-the-country-tonight-to-get-to-Tallahassee-in-the-monrin'
