4010 motor vs 4020 motor
sflem849
03-23-2007 15:48:37
I have searched the archives and I couldnt find the info I needed. (that or I found it and didnt recognize it)
I am putting two people in touch with each other. One has a blown up 4010 and the other has a good 404(?) I know the 404 goes in the 4020, but does it go in a 4010? They look the same size, but I have never taken the tape to them. I know they are different hp by quite a bit but are they the same size/mounting bolts/etc.
Thanks for the info and I appreciate you letting me on this forum ;) (I have a SMTA...shhh)
Gerald J.
03-23-2007 16:34:22
 Re: 4010 motor vs 4020 motor in reply to sflem849, 03-23-2007 15:48:37
The 404 diesel engine has had many variations since it was first used in the 4020. Even the pre and post sideconsole 4020 used different 404 engines. The 404 size has been offered by Deere ever since but that's not enough to know the engines will interchange. Sometimes its a matter of water pump location and length, sometimes the only thing in common is "404." And even the location of the injection pump has not been consistent. Early 4020 404 had a crankcase ventilation pump, late 4020 didn't. The length of engine plus water pump and location of the water pump impacts the radiator and fan location.
Some late 4020 diesel parts will go in an early 4020 (and probably 4010) diesel block but make for a poor starting engine because the deck height is a bit different between the engines.
The 4020 404 engine should fit the 4010, other 404 engines from combines and later tractors may or may not fit without a lot of surgery of tractor and engine.
Gerald J.
