 Its not far from Tom Edison's 120/240 volt DC power distribution system of 1885, except for two things. The value of the voltage and the fact that the generator wasn't center tapped to allow for unbalanced loads. Edison used two generators in series so there could be unbalanced loads on the two sides. The generator ratings used on the new generation tractors are a significant limitation. The 10 amp at 24 volt and 20 amp at 12 volt (like my gas 4020) are great for starting the tractor in the morning and running it until noon (or its about out of gas) and doing the same thing for the afternoon, and then maybe the evening. Its easy at night to use up all the generator rating running headlights so the battery doesn't get charged. Today we use these tractors as utility tractors, and don't often run them the several hours it takes to get the battery recharged from that cold start. So the batteries go dead from not being fully charged, and its blamed on the system when its more a fault of the wimpy generator, the need for balanced loads, and being run for short periods. Not having an ammeter to detect the charging works and is completed doesn't help. I put an ammeter on my gas 4020 (the dash has the places molded for two more gauges used in the power shift models) and all I could see from the generator and original regulator was the needle bouncing from peg to peg. As it was taking a battery a year and often needed an hour with the battery charger before each use, I got mad and mounted an alternator and now I got three years from the last battery. I also changed out the slim battery (which has the poorest CCA to price ratio) and made an extended step with a side terminal on that step for twice the CCA and half the cost. Sure, the alternator isn't stock, but later 4020 and those with cabs came that way from the factory. The alternator puts out a good 14.2 volts and the charge current runs up to 30 amps and tapers as it should even when I run the tractor for a few minutes at a time. So the battery lasts much longer. The wimpy generators are just a detail, but in the modern use of the new generation tractors, a critical detail. Gerald J.
