G camshaft?
58401
03-22-2007 19:00:37
Will a camshaft out of a 70 gas fit an unstyled G?
buickanddeere
03-23-2007 10:42:39
 Re: G camshaft? in reply to 58401, 03-22-2007 19:00:37
Better to get any used cam reground and the followers refaced. You won't gain anything installing a worn cam. You eyes are not accurate enough to check the lobes and followers either. The tractor pulling forum lists several custom shops who grind cams.
ram ranch
03-22-2007 20:47:42
What are you really gaining?
DSK
03-23-2007 06:52:04
 Re: G camshaft? in reply to ram ranch, 03-22-2007 20:47:42
Unless your G has had significant engine modifications, (running more than 500 c.i.) you will see no advantage. Changing the cam out of a G is not a simple task and the swap wouldn't be worth the work in a otherwise stock engine.
ram ranch
03-23-2007 07:53:10
 Re: G camshaft? in reply to DSK, 03-23-2007 06:52:04
oh ya it's a job, dos anyone have any cam spec. G compared to a 70?
DSK
03-22-2007 19:15:48
The later G's had the same cam as the 70 gas, F900R. It will bolt right into any G.
