The 2 terminal switch can be used to energize the starter solenoid when its depressed, hot feed wire from rotary switch and S output to solenoid buttttt ttttt tttt the extra 3rd terminal is necessary so the ballast resistior can be by passed and the coil get unballasted battery voltage ONLY while shes cranking (i.e. starter switch depressed). Trouble (with just a 2 terminal switch) is if you try n tie the ballast by pass wire with the solenoid activation wire, when the ignition is on it will ALSO power up the solenoid THATS A NO NO LOL AND WHY YOU NEED THE CORRECT 3 TERMINAL SWITCH That being said, unless its extreme cold,,,,, , or the engine and/or ignition is in bad shape ,,,,, ,,,or the battery or starter is weak YOU CAN GET BY FINE IGNORING ANY BALLAST BY PASS i.e use the 2 prong switch for the solenoid only n forget about the ballast by pass UNLESS youre a perfectionist or a correct police nut of some kind. If it makes you feel any better just run a dummy wire off the ballast up under the dash near the switch n who else will be wiser????? John T
