2640 or 2750?
nthgrnzlkadeere99
03-22-2007 12:52:50
Hi. I'm looking at buying one of these. Which one would you prefer? Both have similiar hours (around 3000),both look good and run good. Price is close,about 1000 more for the 2750. Any comments on which to buy would be appreciated. Anything and everything to know on them would be helpful. The 2640 is an '80 model and the 2750 is an '83 model. One last thing,both have 18.4-30's new. Thanks.
jd2120
03-22-2007 21:28:27
 Re: 2640 or 2750? in reply to nthgrnzlkadeere99, 03-22-2007 12:52:50
i would defently go with the 2640, a friend of mine had a 2640 and a 2750 cab tractor and the 2750 was nothing but trouble, motor blew at 1700 hours, and was replaced 2 more times, AC would never work, starter selnoid switch went bad, $200 for it, i think they have the Bosch starter which is really expensive to replace and not everybody will work on one, you can get the selnoid for the 2640 for less then 12 bucks. (delco starter) 3 other farmers in the area had 2750's and all but one was junk as well, by experience the 2640 would be the winner.
low budget
03-22-2007 21:11:11
One more thing to consider, the 50 series has an electric tachometer. When comparing hours to the 40 series you can knock about a third of the hours off 50 series.
DeereManJRC
03-22-2007 14:51:54
I'm going to have to say that I disagree with the last comment:). Personally the 2750's are a much better tractor, now of course not everyone will agree with this, but from my experience, the 2750's are really an "underrated" tractor. They are more powerful than given credit for, and they handle very nicely. At the college I went to they had a 2750 that was "student operated" and so had some hard use. It really impressed me that it didn't have many problems. The 2640 is a nice little tractor, but given the choice I would choose the 2750. Another consideration is if either tractor had the hi/lo option, that is very handy, and might be something to consider.
ram ranch
03-23-2007 05:12:11
 Re: 2640 or 2750? in reply to DeereManJRC, 03-22-2007 14:51:54
Sorry my mistake the 2750 replaced the 2640, their about the same but the 2750 is turbo charged, I was getting it mixed up with a 2840, which also owned at the same time,Also had a 2950.But we no longer have any of them, but still have the 4020s & 3020s. We had a loader on the 2750 for a very short time and removed it because it was hard shifting the trans,The 2640 was alot smoother.
cannonball
03-23-2007 15:18:55
 Re: 2640 or 2750? in reply to ram ranch, 03-23-2007 05:12:11
2640 is about 1800 lbs lighter than a 2750...agreed that the 40 has a 279 cu in engine and the 50 has a 239 with a turbo....
MAY GOD BLESS THE USA
ram ranch
03-22-2007 20:36:18
"much better tractor" compared to what? Than you say "2640 is a nice little tractor" the 2640 is a bigger tractor than the 2750, and yes the 2750 is more powerful than given credit for. But it's also turbo charged, and "student operated" any kid is going to like the newer tractor. The only way they run is wide open.(2750). Have you ever ran a New Generation tractor? And the HI/LO handy for what? Catching some dirt in high gear?
ram ranch
03-22-2007 13:34:38
We (had) ownd both of those tractors before noticed I said had. We liked the 2640 it had a loader on it and was a good tractor, we traded it for a 5500 which is alot better tractor surprisingly but we love it. The 2750 thats another story, it sucked! it loose hyd pressure under 1500 rpms when you raked hay, the power steering wouldn't work (at lower rpms). the 3020,4020,4010,2510 and the 2750 would be all in the barn ready to go for haying, and all the employes would rush around to get all the good tractors, and the 2750 was always left behind. nobody liked to run it.So got rid of it and bought another 4020.granted the 2750 is about the same horse power it just dosn't have the weight like a 4020. I think the 2750 was about 80 horse 4 cylinder turbo charged motor. Theirs more things about the 2750 we didn't like but I done, just buy a good 4020.
low budget
03-23-2007 07:58:35
 Re: 2640 or 2750? in reply to ram ranch, 03-22-2007 13:34:38
Not trying to start an argument, but the hydraulic problems you describe indicate a weak transmission pump or leakage in the low pressure system. This ia a weak point in the JD utility tractors, could happen just as easy to a 2640. I have a 2755 mfwd with a loader that I really like, but I use my 4020s for the real field work. The 2755 can handle any job but a 4020 is just plain and simple more tractor.
ram ranch
03-23-2007 10:29:16
 Re: 2640 or 2750? in reply to low budget, 03-23-2007 07:58:35
Yes I agree I had high expectation of the 2750 when purchased, But a 4020 is more tractor, maybe it should be compeared to a 3020. It about like lawn mowers today they have 25 horse but they not a B,or a 50. depends on what your doing with them.You aren't going to be plowing 50 acres with your lawn mower or trimming the lawn with your 50?
