310 Backhoe
Hogman
03-22-2007 09:13:58
This is a JD 421 motor....He bought it rebuilt and assembled.....Always had trouble starting ( have to use either ) Replaced Fuel Pump,Primary Pump,Injectors,Radiator..... .It has been pushing water out the Radiator Overflow..... .Why is it building up so much pressure?? Any input will be helpful..... ..Thanks guys
MSM
03-22-2007 10:11:10
 Re: 310 Backhoe in reply to Hogman, 03-22-2007 09:13:58
It could be a number of things either stemming from the "rebuild" or the use of ether.
If the cylinder head was not rebuilt properly with the correct valve standout, the engine will be very hard to start.Just grinding the valves and cutting the seats drops the valve down in the head,effectively dropping the compression making for a hard start.
Building up pressure in the cooling system can be caused by a blown head gasket,or cracked head. It would probably pay to pull the head and have it checked by a reputable machine shop for cracks,flatness and valve standout.
Also while it is apart, I would also pull out the pistons and check for broken rings from excessive ether application.
Recheck the injection pump timing also as being out of time either advanced or retarded will cause a hard start.
With the head rebuilt correctly,pump timed up correctly and good rings and a good cranking speed that engine should start unassisted down into the teens.
