720 rebuild
pwd
03-22-2007 06:12:17
i need to put new pistons and rings in and just wondered if i could pull the pistons out the crank side? i know what ya'll are going to say-go ahead a do it all the way and i might but i was just wondering if the pistons would come out that way.(it is a diesel)
F-I-T
03-22-2007 16:24:59
 Re: 720 rebuild in reply to pwd, 03-22-2007 06:12:17
Ok..... first, no room for that at all if you have the crank in there, and then I don't think the rods will clear the back vertical wall of the main case, so the pistons will not come back far enough to remove the wrist pins to separate the assemblies. Second...I don't think the pistons will pass through the two fairly small access ports in the top of the main case.
If you are installing new pistons, wouldn't you want to see and measure the bores for taper and runout? You certainly can't do that from the crank side.
Is this a legimate question, or just a poser meant to stump the band..... .?
Frank
Glen in TX
03-22-2007 12:35:58
JD manuals http://techpubs.deere.com 800-522-7448
Might get them out that way using a torch, chop saw and welder? :)
buickanddeere
03-22-2007 11:09:25
As you already know. You will regret taking short cuts.
