720 45 loader
sam in mo
03-22-2007 05:22:55
Trying to hook up loader to run off of a double valve (hyd bucket) on the loader. I thought I could tie the aux. hyd. lever back and run the hyds. off of it but that dosent work. The tractor has 3 levers on it for the hyds. and I will probably have to plumb into them to make this work. I was trying to use a double valve up on the left mounting post so it would be a little handier for me to switch the loader out between a 720 and a 520 JD on diff. farms. On the 720 there is two big cap screw about maybe 15/16,s. Is that where you put the disconects for the other aux. hyd. lever? Dont" have abook yet and hay season is getting here sooner than I am ready for. Thanks to any repiles. Sam
Mike M
03-22-2007 07:52:38
 Re: 720 45 loader in reply to sam in mo, 03-22-2007 05:22:55
My neighbor used to have a 45W on a model 50 with hyd. on the dump and he just tied the lever back and ran the hoses from his remote up to another 2 spool control valve on the loader and it worked ?
F-I-T
03-22-2007 08:31:01
 Re: 720 45 loader in reply to Mike M, 03-22-2007 07:52:38
That is exactly what I do with my 45W with hydro bucket on my 70D. I mounted a twin spool valve set for open center, and the oil just runs form the P-trol through the valve and back to the sump through the "return" hose. When you operate a valve, things move.
Mike M
03-22-2007 07:52:33
sam in mo
03-22-2007 17:00:20
 Re: 720 45 loader in reply to Mike M, 03-22-2007 07:52:33
My loader is just a 45. I dont recall seeing the letter W on it. It works like you say on my 520. Just tilt the lever back and it works the lift and the dump cyc,s just fine. However I tried that on the 720 and it dosent work unless you use the power troll lever and the 2 spool unit together. I tried switching the hoses at the quick changes and that didn't help either. Thanks for the input. Sam
Mike M
03-22-2007 18:09:40
 Re: 720 45 loader in reply to sam in mo, 03-22-2007 17:00:20
There are some settings on those hyd. units under cap nuts. If you have an owners manual it will tell about them. I don't have one handy here to check it out. this may be what it needs.
Forgot to add
03-22-2007 18:11:38
 Re: 720 45 loader in reply to Mike M, 03-22-2007 18:09:40
The W is just the version made for wide front ends. The pipes are curved to clear the axle.
