John Deere D wheel seals
bigmur
03-21-2007 06:58:51
I am looking for rear outer wheel seals for a John Deere D with brakes. John Deere says that they are obsolete. Does anyone know of anywhere I can find these?
Glen in TX
03-21-2007 09:50:42
 Re: John Deere D wheel seals in reply to bigmur, 03-21-2007 06:58:51
The seals are the same whether you have individual wheel brakes or not on a late unstyled D or styled D. Earlier unstyled D felts are bit different though. JD parts online shows the D2455R Outer Felt seals still available about $20 each and the AD1250R inner oil seal available for about $15 each. The inner seal usually needs replaced also and is a lip oil seal Chicago Rawhide number CR29906. The D2456R retainers for the felt seal show to not be available and you need to make sure to not damage those so they can be reused. If you need retainers might try Greg Stephens 303-663-5246 or [email protected]
WeirdDeere
03-21-2007 12:01:23
 Re: John Deere D wheel seals in reply to Glen in TX, 03-21-2007 09:50:42
I'm actually trying to do this right now on the DI. I have an axle off (heavy bugger!)
I removed the inner roller bearing (it just sits in there), but I can't figure a good way to get the axle out. I know it has to be removed towards the "outside". The felt retainer, etc are still on it. I'd like to use the axle to push these off all at once, so it doesn't get bent up. Does this seem feasible?
What do you guys use to remove the axle? I'd beat on it, but I've learned the hard way that is a good way to screw up the threads! We've got a press (at another shop) but I don't think it will go long enough.
Brandon
Glen in TX
03-21-2007 12:53:44
 Re: John Deere D wheel seals in reply to WeirdDeere, 03-21-2007 12:01:23
third party image
Brandon, You have the nut loose and axle off gear and tractor? Originally they recommmended to loosen nut inside and drive in a figure 8 to help loosen it some. Otherwise after nut is loose you get to use wood wedge blocks and large pry bar, not fun. If you got axle assembly off gear and tractor then the axle pushes out towards outside. The spacer #22 and lip on axle keeps it from going toward inside. Put the nut back on end of threads and watch toes and chin or find a helper and drop it down on some wood and it should pop loose. Might have to bolt on some scrap flat or angles to housing to help hold it better but they usually pop loose dropping them like that just be careful because of the weight and don't let it fall on you. In DIR225 for 31 to 38 D they just tell you tighten the nut back as tight as you can get it with a 15 or 20 inch wrench (monkey wrench or cresent or correct size) where there is no binding when turning and replace the cotter key in nut on end of axle. No fancy cheater or torque wrenches needed.
WeirdDeere
03-22-2007 01:19:54
 Re: John Deere D wheel seals in reply to Glen in TX, 03-21-2007 12:53:44
I just realized that my earlier post made almost no sense. Sorry about that, that's what happens when I post in a hurry before work!
Already have the left axle housing/axle off of the tractor. The only hard part was breaking loose the nuts for the housing.
I had been trying to figure out how to get the axle out without boogering up the threads. I had tried some gentle drops on a hunk of wood, but since you also suggested dropping, sounds like I just need to be a little more persuasive/violent!
Brandon
Glen in TX
03-22-2007 05:26:27
 Re: John Deere D wheel seals in reply to WeirdDeere, 03-22-2007 01:19:54
It made sense to me but I just don't remember having to tote any over to the press to get them loose. Maybe we did support some with outer side down using some wood and hammer to tap them out. Wood over the thread end also.
