problems with a g - sheet metal oil leak
johns48jdb
03-20-2007 21:00:19
i looked at a g this afternoon and there was oil dripping off the the guard around the flywheel. i know on my b there is a cork seal back there, but i don't know antything about a g. could there be a bearing problem along with the cork seal leaking? the pulley moves in and out while the engine is running. i think this might be causing the oil leak. on the sheet metal the front grills are bowed out in the center at the bottom on both sides. it looks like they were done that way to clear something, but i couldn't see anything behind them that needed to have clearance. also the railings that are on the grills that the screens fasten to were out of alignment. if you looked at the front of the tractor the one on the right side had the top railing dropped down by nearly 1/2 inch. is this a common thing? i could see no reason for it being like that unless one side had been replaced by a different year model. thanks.
