4450 engine
twsgrey3050
03-20-2007 14:02:14
hey,i am looking at a deere 4450 with the quad range. it has 9500 actual hours. seems to run good and look good. it is a 1 owner tractor and the original owner says its the best tractor he has had. he said he replaced the radiater and thats all. my question is,how many hours do you think i can get out of this tractor before overhauling it? it seems to run good as i said,doesnt smoke,and i was told it doesnt use excessive oil. i have been told that this particular tractor is one of deeres better machines but still want more information. i am hoping to run it to 20,000 plus hours if possible,so im thinking long term. thanks in advance.
jared in wi
03-21-2007 18:53:56
 Re: 4450 engine in reply to twsgrey3050, 03-20-2007 14:02:14
well, it depends on the care that it has recieved. one of our customers has a 4450 as their TMR tractor, and put on over 30,000 hours on it. of course it was underhualled once or twice. one thing i would suggest, would be to underhual it right off the bat.
JMS/MN
03-20-2007 22:09:50
I have a 4430 with 10800 hrs, 4240 with over 8000 hrs, 4450 MFWD with 9200 hrs. 4430 had an underhaul done at 8700 hrs. All three have original engines, no overhauls, original PS transmissions and rear ends. 4430 uses a pint of oil in 100 hr oil change, others use none. They're all keepers with that kind of service record.
jhill52
03-20-2007 20:15:50
I know of a bunch of 4440's with 20,000 hrs on them and no overhaul. If they are maintained they go a long time. If anything it may need an underhaul - rods and mains and can be done by dropping pan only.
Mike w J
03-20-2007 17:07:41
I would have to disagree with houndog Those tractors register an hour for every hour the key is on no matter what RPM or load the tractor was used for around here dealers say you can deduct about 30% of those hours when compared to a machanical hour meter and many of them ran far over 10000 hours .My dad has a 4450 with 10300 hours on it cuts silage about 100 hours a year The rest is loader work hauling round bales and feeding cattle at 1500RPM or less . It runs as good as the day he bought it new . I think a tractor that is worked a little harder should be in just as good or better shape then his. Service Service service By the book does PAY.
Houndog
03-20-2007 14:18:56
I would say, on average, you are looking at a overhaul now. 10,000 hrs. is about all you usually can get. If it lasts longer, great, but know going in a overhaul may be neccessary in the near future, i highly doubt youll see 20,000.
