36 B rear axle seals
Russell S.
03-20-2007 12:36:12
I am trying to remove the dust covers from the axles of my 1936 B. I need to replace the oil seals and check the bearings. How do I remove the outer dust cover without bending it so bad. I can get it out about a 1/4 of an inch but thats it. Thank for your help.
Russell S.
03-21-2007 03:41:25
 Re: 36 B rear axle seals in reply to Russell S., 03-20-2007 12:36:12
Thanks for your help.
Russell
Deere-Tom
03-20-2007 19:24:45
Yes, you have to remove the axels to replace seals. The seals are in the rear end housing. This sounds hard but you will need to clean out the axel housing anyway. I would pick up a IT manual or one from deere. you will need it and keep asking questions we will help.
ram ranch
03-20-2007 13:22:09
remove the axles and fix the inner seals and the outer seals and be done with it. The outer seal aren't going to stop the leak, on the nicely yellow painted rims.
Jim Benson
03-20-2007 13:04:18
If it's the same as te 36A, theaxles have a flange that is outboard iof the seal retainer so the axle comes out first.
Russell S.
03-20-2007 12:55:34
OK. So I can't replace the outer seal without pulling the axle? I thiught there was a seal just behind the cover.
Mike M
03-20-2007 12:48:22
Don't those have bolts holding them in ? After the bolts are out when you take the axle out they should come out with it. The oil seals are on the insides of the housing next to the bull gears in case you didn't know.
