4010 Hydraulic issue # 2
Ken Powell
03-20-2007 11:47:06
# 2 problem with 4010 industrial...there are two steel lines going to rear hydraulic connections.
One of the lines has a hole that will blow fluid when hyd lever is engageded and will leak slightly when not. the tranny seems a bit sluggish and may be worn out or may be suffering from issue related to leaky hyd line...any thoughts??? Yes, I plan to fix the line...Ken-281-460-5827
TimS in Mo
03-22-2007 08:43:01
 Re: 4010 Hydraulic issue # 2 in reply to Ken Powell, 03-20-2007 11:47:06
Not sure on the transmission, but you can either try brazing/welding that hole shut or just replace the steel lines with 3/8 rubber hoses....
