JD 4020 3-point lift capacity
JD4020 3-point
03-19-2007 19:27:13
Is there anyway to increase the 3-point lift capacity of a John Deere 4020? My understanding is they have around 3500 lbs lift capacity and a 4230 runs around 4500 lbs. Do they have a lift assist kit available or will the lift assist kits off of the 30 series work. My understainding is a lift assist cylinder will increase capacity but I don't know if I can put one on a 4020. I plan to put a loader on the tractor so counter weight should not be a problem. Any information is appreciated.
Thanks,
Harold
JD330V
03-21-2007 19:37:07
 Re: JD 4020 3-point lift capacity in reply to JD4020 3-point, 03-19-2007 19:27:13
I purchased a 3-point fork mast that is capable of lifting 5000 lbs, and the unit weighs more than 2000 lbs by itself. I would like to buy a John Deere tractor but if I want that kind of lift capacity I either need to buy a 4440, or purchase something like a 4520 but then I am stuck with a tractor that is capable of only a 1000 RPM PTO. I prefer to buy a JD, but for a lot less money I can purchase an old Oliver 1850/1855 that has an optional 3-point lift capacity of 6000 lbs which is double a 4020. It supprises me that the Oliver has that rating but the book states those figures. I would prefer the Deere, but since this tractor will be more of a toy I don't know if I can justify the price differance. That was why I was wondering if they have a lift assist kit that could be purchased just like you can on a 4430. My understanding is if you put one on both sides it will increase 3-point capacity up to 2000 lbs. This would get me close to where I want it to be. I just don't know if you can get a lift assist kit for a 4020?
Mike M
03-20-2007 04:54:43
Why not lift it with the loader ? If you must have that kinda rating on the rear then I'd be looking at a bigger tractor.
