Carb question for Duane Larson
Hig 5060
03-19-2007 19:05:46
I asked about my 44B having a DLTX10 carb. on it and you said it wasn't right but should be OK. But its always been a little hard to start,could this be part of the problem? It is a hand crank but I know it should start fairly easy. It runs fine when running just hard to get going. The spark seems to be pretty good. It hits a lot but won't go on and start. Sometimes it takes 2 or 3 cranks and sometime it takes 12 0r 15 It always starts but you never know when and its hard on me after 10or 12 cranks.Thanks for your advice.
John T
03-20-2007 06:31:24
 Re: Carb question for Duane Larson in reply to Hig 5060, 03-19-2007 19:05:46
Hig, Now that Duane n others have weighed in I will add my agreement. I agree (unless the carb is really really bad and misadjusted) a hard hand start is more likely ignition than carb related. Your Mag MUST yield a hard healthy robust SNAP indicating a good strong spring wind n trip assembly absolutely necessary for hand starting. Then it must occur at the correct time, if too late shes hard to start n if too soon the flywheel could kick back. Mine are set to snap somewhere between TDC and maybe a degree or 2 before, but NEVER after. To get that hot strong spark, in addition to a good spring trip impulse assembly, the points gotta be clean and not gray oxide coated and NOT burned or pitted and gapped properly with good fresh clean hot plugs and wire core NOT carbon suppressor plug wires.
YOU NEED FRESH CLEAN WATER FREE GAS OF COURSE
You might wanna get her running and fine tune n tweak the carbs idle n load needles and I start mine with the throttle cracked just above idle,,,,, get the left piston at TDC on its exhaust stroke (just ready to go down n suck in gas),,,,, ,,choke her 3/4 to full (depends on if hot or cold) ,,,,, rapidly spin the flywheel a half turn or so (grab n catch so she dont bounce back) to suck in gas,,,,, ,,,,turn the choke off to 1/2 (depends if hot or cold),,,,, spin her over on compression n she usually (unless dudes are watching lol) starts either that first pull, but if not 3 or 4 pulls later.
I think its sooooo ooooo easy to overchoke n wet gas foul the plugs which is when you see dudes crank n crank n crank before they start. If they get wet remove n clean n dry them n start over is my advice. I dont think one SHOULD EVER have the choke full for anymore then 2 pull overs before opening it and then she oughta start provided shes not flooded. I also am of the opinion when shes full choked and she pops on that first cylinder but then dont run (and then it takes lots of cranking before she ever fires again) its cuz the second cylinder got flooded cuz you cant shut the choke off fast enough. I Think?? thats why the electric starts used the spring loaded choke plate n the hole Duane mentioned.
Get a good loud sharp mag SNAP n a strong hot blue starting spark, adjust the carb n impulse start timing at TDC or a tad before and dont over choke her n see what happens
let us all know
John T
WeirdDeere
03-19-2007 23:21:19
Have a '46 B with electric start, and as I found out went I rebuilt the carb, a DLTX10. We've had no issues with it, it usually starts just fine by hand or starter (of course there is always a cantankerous day or two!)
Brandon
CalJim
03-19-2007 20:11:40
I know this post was for Duane Larson but I
wanted to share some more info....I just finished
putting together the rebuilt motor on my 36 B.
It would start but not consistently. Sometimes
3 pulls, sometimes 10-12 pulls. I was choking it
the same way I start my 44 B, choke till it pops,
choke off and starts right up. Took me almost 2
weeks to figure it out. Choke. 1, maybe 2 pulls.
Choke off. Starts right up. I learned they all
have thier own "combination". CalJim
Duane Larson
03-19-2007 19:33:58
Hig 5060,
I doubt that using the 10 instead of a 34 on your tractor would be the primary cause of hard starting. Hand crank tractors normally had a solid choke plate, and when they generally went to electric start the choke plate had a hole - sometimes a flapper - to reduce the choking effect when it spun over (most electric starters can spin a tractor over faster than one can turn it by hand). Choke plates with holes became the norm, so you might check if your choke plate has a hole in it which could reduce the choking effect. The starting process depends on fuel from the idle circuit (particularly if you have the throttle in a slow idle position) so you might try opening the idle needle some during starting. Also play around with the throttle setting and amount of choking.
Timing is also important, and you can check your running and starting timing with a battery and a timing light - search the archives as this has been covered often by myself and others.
All of my tractors have their own preferred way of starting and sometimes it takes some mapping of the various parameters to find the easiest starting situation. I wish I could give you a sure-fire way to start on the second pull....
JD @ Antique Acres
03-19-2007 20:02:48
 Re: Carb question for Duane Larson in reply to Duane Larson, 03-19-2007 19:33:58
I would just like to say that I had a DTLX 19 carb that had those same symptoms, hard to start but ran good after it was started. Turns out the the idle circuit was partially plugged, I cleaned it again and now it starts in one or two pulls. This may or may not be your problem.
