Bull gear for MT, screwed up again.
Dirt_Farmer1950
03-19-2007 15:18:35
I hope your all not tired of hearing from me, but I screwed up again. Got my replacment bull gear from Ebay, It's in excellent shape, but not the same as I took off. The one that came off the tractor is # M999T 73 tooth, the one I purchased is a M1484T and has 74 teeth. Can any one look these up to see what the pinion count should be for 74 tooth bull. I'm just trying to do my homework before I spend money again.
Thank, Jeff
Dirt_Farmer1950
03-20-2007 13:01:34
 Re: Bull gear for MT, screwed up again. in reply to Dirt_Farmer1950, 03-19-2007 15:18:35
Thanks guys, I didn't realy think this tractor would need as much as it does, but it will get there. I just won't be driving it around as soon as I had hoped.
I checked the other side and it has the same M999T bull in it so they may have been changed at some time? jd52mt do you have a listing of what the M999T is for?
Thanks to jd51mt for correct #s
Serial Number 10001 - 28432 Pinion M 204 T sub. for AM 773 T, Gear AM 936 T sub. for AM 970 T
Serial Number 28433 - up Pinion M 1483 T sub. for AM 1533 T, Gear Am 1532 T sub. for AM 1534 T
Mine is serial# 22631 so it should have the earlier gears.
Thanks again, Jeff
Dirt_Farmer1950
03-20-2007 17:54:22
 Re: Bull gear for MT, screwed up again. in reply to Dirt_Farmer1950, 03-20-2007 13:01:34
FYI I put the above part#s into JDparts, and none of them come up as a gear, I think AM773T & AM 1532 came up with no description. And the rest where invalid.
Both the M999T and M1484T both come up as "ring gear, final drive"
I don't know if that means anything, just what I found.
I do think I have found another M999T bull gear though.
Thank, Jeff
jd51mt
03-20-2007 07:41:18
Jeff,
It looks like M 1484 T is for a model 40T (tricycle). The pinion listed for this gear is M 1680 T. Neither of these numbers are listed for the model MT. May be someone who knows about model 40's can tell you if they can be made to work.
MIke
Henry M
03-20-2007 06:28:54
Jeff
Remember that I ran into that bug a boo with the pinions on the 420. Those did not have numbers on them and if I recall even the ones with the same no of teeth had two different widths between the teeth depending on what the sn of the tractor was.
Is yours showing a sn? That could be another bag of worms.
Mike M
03-20-2007 05:10:31
I'd say first off you need to find out what number is to be in there according to the parts books. Could be yours had the wrong one in it and that's why it broke ????? Hopefully someone has a book handy and can give a quick response.
tstex2
03-19-2007 16:07:37
Jeff,
You can go to John Deere's website and sign yourself up. You can then enter the part numbers you referred and it will give you part information.
I know is it real easy to speak in hind-sight, but did you confirm you were purchasing the same part number off e-bay that you got off your MT tractor? If the seller did not give you the correct info., you have recourse; if you did not give the correct info, you can resell or trade.
good luck,
tstex
Dirt_Farmer1950
03-19-2007 16:23:57
 Re: Bull gear for MT, screwed up again. in reply to tstex2, 03-19-2007 16:07:37
It's my fault for not checking the #s first, just assumed they would be the same because they where both MTs. I'm trying to see if the same seller has the pinion available, might wear the differential gears out with one side slower then the other. I'm pulling the cover on the other side tomorrow to count teeth and check the # on it.
I'll try JDparts again, my slow dialup doesn't like it much.
Thanks, Jeff
