Flooded carb 2010
Dale Berry
03-19-2007 14:06:42
I recently rebuilt the engine in my 2010. Everything went well except I am having trouble getting the carberator (Marvel Schebler TSX 810) to quit flooding. I rebuilt it as part of the engine rebuild and can"t seem to figure out why it wants to flood so bad. Anyone out there had similar problems or have any ideas? I appreciate you comments. Thanks, Dale
Glen in TX
03-19-2007 16:01:16
 Re: Flooded carb 2010 in reply to Dale Berry, 03-19-2007 14:06:42
Make sure the float isn't rubbing on side of housing or needle not shutting good. Shut fuel off at sediment bowl when not in use. New needle seat still won't help if fuel is dirty full of crud to hold needle open. The gasket was replaced under the new needle seat? Surface of housing to seat was not pitted or corroded? Float was set to correct height as recommened in kit? Was the float collapsed any? If so replace it to restore buoyancy needed to shut needle. Shake float listening if it is fuel laden with gas inside. Can also test float for holes by holding float with pliers in pan of hot water (not boiling) and watching for air bubbles spewing out where float has a leak. New TSX floats and kits are available.
