Carb kit for a 720 pony motor
gahayfarmer
03-19-2007 13:46:42
I have a 58 JD 720 Diesel. Does anyone know if I can get a carb kit from John Deere parts for the pony carb?
Thank you,
Scott
Glen in TX
03-19-2007 16:17:36
 Re: Carb kit for a 720 pony motor in reply to gahayfarmer, 03-19-2007 13:46:42
If things are very worn and you need the complete kit the JD one FIT mentions is best way to go. Otherwise just gasket & seal kit. Zenith still furnishes a K2067 kit for TU3.5 that is just gaskets, seals and needle seat set for about $36 and NAPAs might have a similar kit.
gahayfarmer
03-20-2007 12:04:09
 Re: Carb kit for a 720 pony motor in reply to Glen in TX, 03-19-2007 16:17:36
I went to Napa and they were not able to look up the parts for the Zenith carb. Does anyone have some Napa part numbers for these carburetors?
Thanks to everyone for the help thus far.
Scott
Glen in TX
03-20-2007 12:36:38
 Re: Carb kit for a 720 pony motor in reply to gahayfarmer, 03-20-2007 12:04:09
No one else stocks kit because it doesn't fit anything else so if NAPA can't cross the current Zenith K2067 kit number forget it. I don't stock them and only special order because there isn't much demand for those kits but they are still in the current new Zenith/MS price list.
F-I-T
03-19-2007 14:23:21
I bought the gasket kit for two different ones and they came from Deere. I also got a kit from Robert's, whose parts are generally very good, but there were more items in the Deere kit, and the price was less than Robert's. Hard to say why.
I'm not sure of the contents of these kits, but I think you might get a throttle shaft and jet and such in the higher priced kits, but they are indeed pricey. Here are the kits that show available:
AR 13015 Gasket Kit $ 13.72
AR 13005 Carb Service Kit For non-serialized starting engines. $190.40
AR 13003 Carb Service Kit for S/N 1000 and up SE"s $140.00
gahayfarmer
03-20-2007 08:43:21
 Re: Carb kit for a 720 pony motor in reply to F-I-T, 03-19-2007 14:23:21
Deere quoted me about 125.00 dollars for the kit that comes with the needles, gaskets, seals, and foam washers. (not sure what they mean by foam washers) Whatever kit I get needs to have the long brass hollow jet that goes across through the center of the carb.
Scott
F-I-T
03-20-2007 14:14:09
 Re: Carb kit for a 720 pony motor in reply to gahayfarmer, 03-20-2007 08:43:21
Oddity of oddities, that tube, which I would have called a spray bar, but they call an "Idle jet" is available as a single piece for $8.95, P/N AR 13009 R.
Based on the prices of these little carb parts, and the fact that they seem to be headed for discontinuance, I would go order one right now!
Some other parts are available piecemeal as well, and then you get "almost" everything in the $190 kit.
Frank
Mike M
03-20-2007 12:51:49
Last ones I did I was just able to get the parts seperate from Deere. Gaskets,needle & seat,and even that nozzle. Price wasn't even that bad this way.
