2940 fluid leak
audie
03-19-2007 08:46:34
i have a jd 2940 with a hydraulic fluid leak. it seams to be comming from around the gear shift levers. how do you get the plate off that goes around these shift levers, so i can make sure that is where it is comming from. fluid can be seen on both sides of the transmission housing. any other ideas.
thanks
deereford
03-21-2007 18:43:57
 Re: 2940 fluid leak in reply to audie, 03-19-2007 08:46:34
I had the same problem and discovered when I steered the tractor it leaked worse-bad steering hose!!
