JD 3010 wont' start
fbmustang1969
03-19-2007 06:11:45
Father-in-law's JD won't crank. Turn key, nothing. Batteries are charged. Tried to jump starter with cables directly from battery, arched. tried key again and it turn over, but I forgot about the "Stop" switch ( Never worked on tractors before, car and truck, many times!) Later on tried the key again....nothing. tried the cable jump again, got the arch, but when the key was tried again...nothing. Is there a wiring diagram online that shows how everything is to be? Could the problem be the switch, solenoid, or even the starter itself?
Thanks for any input.
Bob
03-19-2007 06:24:08
 Re: JD 3010 wont' start in reply to fbmustang1969, 03-19-2007 06:11:45
Be careful you don't run yourslf over jump-starting it. Be SURE it's in park!
Check the safety neutral-start switch under the dash operated by the shift lever. (Follow the yellow wires!)
fbmustang1969
03-19-2007 11:06:50
 Re: JD 3010 wont' start in reply to Bob, 03-19-2007 06:24:08
Thanks, I"ll email my Father-in-law. (The tractor is in Oklahoma, I"m in Ft Bliss, TX).
Any ideas to where I can get a wiring diagram for this JD 3010?
Bob
03-19-2007 11:32:04
 Re: JD 3010 wont' start in reply to fbmustang1969, 03-19-2007 11:06:50
A helpful dealer often is willing to make a copy of the diagram.
Bob
03-19-2007 11:32:00
