1952 John Deere B
tractor Hank
03-18-2007 17:56:32
I am looking at a straight ok painted 1952 John Deere B with new tires and a factory 3 point hitch. It starts and drives OK, but it has a lot of blue smoke. I have several tractors, but have not overhauled a JD. If I do the work, approx what will it cost to do a top end job on this tractor. Also, the governor lopes unevenly -how much trouble is that? Thanks, appreciate any help and would also like rough idea what it is worth
happy deere
03-19-2007 16:27:56
 Re: 1952 John Deere B in reply to tractor Hank , 03-18-2007 17:56:32
one thing you might want to check out for is the oil pressure on my gAUge after i overhauled my 41 b i changed the oil pump and my fresh overhauled motor looked like a mosquito fogger the gauge said it had ok preesure though so i went to autozone and got a electronic oil pressure gauge $45 and checked it it said 32lbs my motor was set to run on only 16 tops so it shure would be nice to do that then overhaul a motor also check the oil bath air filter the wrong weight will suck the oil into the motor causing it to burn. now when i rebuilt my little b i put all new pistons and everything in it now myn is a 41 but if its over $500 then i will be suprised unless you go in the head had myn rebuilt for 150
happy deere
03-19-2007 16:27:38
happy deere
03-19-2007 16:27:39
