70 lp tank question
texasj
03-18-2007 16:50:51
Has anyone ever coverted there lp tractor to a set up similar to a forklift lp set up (removable tank). I ask this because my tank is a little rugged and dont want to risk it blowing up.
Mike M
03-19-2007 09:34:14
 Re: 70 lp tank question in reply to texasj, 03-18-2007 16:50:51
As long as the saftey pressure relief valves are working I would think if rusted ? it will just spring a small leak first at the rust hole. This is what air tanks do.
You should be able to test it or have it tested somehow.
BLinWMi
03-18-2007 20:56:54
Funny you ask, this is exactly how my 70 is set up right now. We had an old Allis forklift at my warehouse that isn't needed. I took the tank off it and it is chained up to the frame on the flywheel side right below the converter. I borrowed a fuel line from the 70 and a fitting from the Allis and plumbed the portable tank right to the factory soleniod/fuel filter. I had bad lp valves on my tank but have since replaced them, did a little engineering so I can drive the 70 down the road to the propane filler place, have the big one filled, switch one hose connection and drive home using its own tank.
A guy can be pretty creative with propane, lines can be made from copper line or small hydraulic line, so any type of tank can be made to work, just have to figure out a way to carry it on the tractor
Glen in TX
03-19-2007 08:54:53
 Re: 70 lp tank question in reply to BLinWMi, 03-18-2007 20:56:54
As long as you feel safe with copper or hydraulic line it's your tractor and your life but those are NOT rated for LPG use. Creative maybe but safe NO! Rated LPG hose is available from your LPG dealer along with crimp on or reusable hose fittings. Your dealer filling it that way apparently has no thoughts for your safety. Copper flakes off inside and can crack or get weak on something moving or vibrating. Other non rated LPG hoses can burst, leak or break down the same. Just be safer with it if you can is all I'm saying.
