JD 4020 Park gear does not hold
Ralph Wilks
03-18-2007 16:14:34
Can anyone tell me why when I put my tractor in Park it does not hold the tractor? It seems to hold better when the tractor is facing uphill than when it is facing downhill.
SwedeDeere
03-24-2007 13:52:52
 Re: JD 4020 Park gear does not hold in reply to Ralph Wilks, 03-18-2007 16:14:34
When you pull the lever to park, a cam on the shaft (the shaft trough the side of the transmission) presses on the roller R66670 which is mounted on a shaft R34371. This shaft is mounted on the parking pawl. My old shaft had snap rings F2208R at both ends, while the new one had cotter pin 11M7021 and a pin fastener AR44553 at one end. A cotter pin is much easier to use in that tight place. To gain acces to these part, you remove the transmission cover at the position of the shaft through the transission side, i can�t remember which cover it was. Good luck!
SwedeDeere
03-19-2007 12:19:37
I had the same problem. There is a roller pressing on the pawl. This roller had fallen off, only the shaft pressed on the pawl. You can buy a replacement roller with an integrated shaft, so it easier to replace.
Ralph Wilks
03-19-2007 13:17:11
 Re: JD 4020 Park gear does not hold in reply to SwedeDeere, 03-19-2007 12:19:37
How much work is involved in replacing roller with the integrated shaft? Do you have a part number for this new part so I could order one?
Thanks,
Ralph
SwedeDeere
03-20-2007 12:31:24
 Re: JD 4020 Park gear does not hold in reply to Ralph Wilks, 03-19-2007 13:17:11
You have to lift the top of the rear end, so you can see the lever. Then reach down with your fingers and you can remove the old one and the new one is locked with a cotter pin. If I remember right! I can check the part number at the end of the week.
Glad to help!
Mike M
03-19-2007 06:04:10
That's been my ( limited ) experience with them.
The lack of a solid park and being very hard to get out of park once in are the 2 main reasons I don't like the power shift tranny. I put a new park pawl in one that had a broken one and I tried everything, but it just acted like yours. Would latch good one way ,but the other it sometimes ratched out. This was an early model and I see there are a few different parts used in the later models so ? maybe ? these work better ?
Ralph Wilks
03-19-2007 07:08:07
 Re: JD 4020 Park gear does not hold in reply to Mike M, 03-19-2007 06:04:10
Good information. The dealer I bought it from had it on consignment and claimed that the tranny and engine had been recently overhauled. How much overhauled and to what extent is anyones guess.
If it works in one direction and not the other seems to indicate that the cable is not broke but may be out of adjustment. I need to check it out.
Can someone tell me what the different combination of letters and numbers mean in the serial number of the tractor. They are as follows: SNT213P102413R. I take it the 102423 would indicate it was made in the year of 1965 but does anyone know what the other letters and numbers indicate. I know you tell can a lot about car VIN numbers and was wondering about the tractors.
Thanks for your help Folks..
F-I-T
03-19-2007 11:36:56
 Re: JD 4020 Park gear does not hold in reply to Ralph Wilks, 03-19-2007 07:08:07
THe best explanation of the serial numbering of the new generation that I have found is posted on forty-twenty.com
Here is the breakdown of yours:
T 213 P 102413 R
T = Basic Tractor. T in the is postion indicated a '65 or newer year model.
2 = 4010, 4000, 4020 model
1 = Rowcrop chassis
3 = Diesel
P = Powershift transmission
102413 = Serial number. It'a about halfway through the '65 model run
R = Waterloo plant
Hope this helps.
Mike M
03-19-2007 07:42:33
The reason ( I figured ) for working one way better than the other has to do with the design of the pawl. If you take off the top cover and look or maybe a book would show it clear enough ? you will see that it pivots in on an arm and it goes into the helical cut bevel gear so one way it gets sucked into the bevel gears tighter and the other way the gears are trying to push it up and out as it goes in. I'm thinking the syncro range uses a collar to lock the park in them and they work alot better and safer. Plus on a syncro range when it gets stuck from pressure on a hill you can still put it in a low gear and move just enough to relieve the pressure and hear the park pop out. The small Deere utilitys were bad for getting stuck in park too. The later ones came out with a hand brake which I like better,but tend to forget to release.
HTR
03-19-2007 09:36:31
 Re: JD 4020 Park gear does not hold in reply to Mike M, 03-19-2007 07:42:33
The power shift, also, has spring loaded linkage to allow shifting to the opposite direction to release the park.
Mike M
03-19-2007 09:53:48
 Re: JD 4020 Park gear does not hold in reply to HTR, 03-19-2007 09:36:31
Ours didn't. The spring on it was just to pull the pawl up in if it wasn't aligned exactly when you put the handle in the P position. I remember having to bang on that handle with my hand to get it to come on up out of park. These were early ones maybe later ones had different features ?
Ralph Wilks
03-19-2007 08:48:03
Yea, that makes sense. When it warms up again I will go out and investigate a little more. Too darn cold to go out and crank on wrenches when I have others to use.
Thanks for the info. I post a response when I figure out what the problem is.
Bob
03-18-2007 16:21:49
Powershift or synchro?
Ralph Wilks
03-18-2007 18:57:54
 Re: JD 4020 Park gear does not hold in reply to Bob, 03-18-2007 16:21:49
Power Shift
Thanks for the reply
Bob
03-18-2007 19:12:14
 Re: JD 4020 Park gear does not hold in reply to Ralph Wilks, 03-18-2007 18:57:54
I have a powershift too and have to lube the cable and linkage from time when it quits working.
I have a new park cable on hand and need to get it installed to see if that is a long-term solution to the problem.
