3020D oil leak @ speedo cable
WheredaFoxhat
03-18-2007 07:49:15
My 68 3020 has oil leaking (weeping really) from where the speedo cable goes into the block, and from the joint between the block and the transmission on the left side. The motor was supposedly rebuilt not too long ago. Oil level isn"t falling enough to notice, but then I don"t use the tractor a whole lot any more. Any ideas? I will try to post a picture if I can figure out how.
Bob
03-18-2007 08:56:34
 Re: 3020D oil leak @ speedo cable in reply to WheredaFoxhat, 03-18-2007 07:49:15
There's a little oil seal that goes inside the tach drive.
There's NO gasket between the engine and the clutch housing 'cause there's no NOT supposed to be any oil n there.
Apparently there's an oil leak at the engine's rear main seal or the transmission input shaft/PTO shaft.
