47 B idle speed
JOE-ILLINOIS
03-17-2007 19:47:06
I can't get my 47 B to idle down real slow with idle screw, is the adjustment screw wore or is it in the carb, thanks joe
P Browning
03-18-2007 06:40:35
 Re: 47 B idle speed in reply to JOE-ILLINOIS, 03-17-2007 19:47:06
Joe -- a couple things to give thought to in this case. One is that the idle speed for your tractor will be considerably higher than for Models A, D or G; so if you are comparing the idle speed of your tractor to one of these models - yes, it will appear high. Idle speed for a model B tractor is 600 - 650 RPM - compares well with the Model H tractor. How are you measuring your idle speed? Do you have a pretty good idea that it is in fact too high?
Then, of course, there are linkage adjustments. Make sure your governor-to-carburetor linkage is set as close to "on-the'money" as you can get. This one gets many folks. With the engine NOT running and throttle lever in full-ahead position, remove throttle control rod at the carburetor. Without pulling on the governor spring, the rod should appear too short to go into the hole by 1/2 width of the rod.
If the "1/2-hole" test fails, you need to adjust the length of this rod -- and it can be a major challenge if the adjustment hasn't been changed in a long time. Be careful. Twist-off is highly likely. So have a plan if it does break when adjustment is attempted. And saving the fitting is well worth the effort -- I think they are still available from Deere -- but for amounts in excess of $50!
The other comments given to you along with this one pretty much covers the waterfront. One parting comment -- really slow idling engines sound nice but plug fouling can be the down-side. (PatB)
JOE-ILLINOIS
03-18-2007 05:00:46
I was talking about the carb idle screw, thanks I will check the governor stop screw, joe
gmc ronnie
03-18-2007 02:40:26
are you talking about the metal bar coming off the govoner,
Jim Broughton
03-17-2007 21:09:45
Joe; Check your governor set screw setting for idle. Best of luck Jim B.
