1931 GP Oil Pressure
40 JD G
03-17-2007 19:14:55
I am working on a 31 GP, Is there some way you are supposed to prime the oil pump. I have not started it yet and i am trying to get oil pressure by cranking it. Also the oil filter on the top of crank case has that pump, what is that for? Thanks
ET
03-18-2007 04:07:03
 Re: 1931 GP Oil Pressure in reply to 40 JD G, 03-17-2007 19:14:55
Some grease in the oil pump will help it pick up the prime. You might try taking the top off the oil filter and filling it up. The back flow of oil to the pump might get it primed. Turning the engine over backwards might draw the oil back to the pump. The plunger on top of the filter forces oil from the center of the filter backwards out the brass element to back flush sludge off the outside of the filter. Turning my GP over by hand makes enough oil flow and presure to raise the red head indicator. Let us know how you made out.
