Wow, several weeks ago posted here with the exact same problem which was baffling. Maybe you can search for that string I changed the fuel filter which was completely clogged (just "inherited" the tractor) but that was not the problem. Turns out it was the fuel return line coming from the top of the fuel injection pump. Apparently there are some gaskets inside the fuel injection pump that can disintigrate with age and break up into coffee-grounds size. These will get clogged in the glass ball vavle that is inside the fitting(s) between the fuel return line and the injection pump. I carefully removed the return line, then the two-piece fitting after that, each piece in turn. Sure enough, there is a glass ball inside one of the fittings and there were a goodly bit of these black coffe ground chunks. Lightly tapping and blowing through it cleaned everything. I also put a large pan under the tractor to catch the diesel and ran the engine for awhile letting the diesel drip into the pan. It ran great so I reassembled. The caveat is that the black chunks represent a kind of seat between metal parts so a fuel injection pump rebuild is not far off. But this might get you back running as it did me.
