4020 clutch problems
oc4020
03-17-2007 18:00:57
I hope someone can shed some light on a solution to my problem. My 4020 is a 67 model diesel synchro trans that I bought a month ago. I adjusted the free travel on the clutch pedal and now when I engage the pto it partially releases the main clutch and the pedal gets stiff to return and sometimes have to pull it up with foot and clutch seems to slip with pto engaged. Clutch seems to work fine with pto disengaged. This is the first time I have tried the pto since I adjusted the clutch. Was wondering about an adjustment that I might have missed. I have worked on these several years ago in a local repair shop, but you know what they say use it or lose it. Thanks for the help.
lonzo
03-17-2007 18:47:49
 Re: 4020 clutch problems in reply to oc4020, 03-17-2007 18:00:57
i would take the cover off that is under the clutch housing and have somebody work the lever and pedal and see what is going on.
