Correct way to adjust Govenor on JD 303 Gas Engine
Willy-N
03-17-2007 17:58:16
How do you adjust the govenor on the 1967 100 HP JD 303 6 Cyl Gas Engine? It seems to work great set at 2500 RPMs but when I set it at 1500 RPMs it does not regulated the RPMs like it does at 2500 RPMs?? I need it to maintain 1,500 to run a generator so as load incresses the RPMs will come back up. Thanks for any help. It has 2 adjustment springs on 2 threaded rods if that helps. Mark H.
Bob
03-18-2007 01:34:44
 Re: Correct way to adjust Govenor on JD 303 Gas En in reply to Willy-N, 03-17-2007 17:58:16
That governor was set up to control RPM's over a narrow range for the combine and you're now out of it's range of sensitivity at the lower RPM's.
To make it more sensitive at the lower speed you are running it at try moving the pivot point for the spring nearer to axis of the governor lever.
Willy-N MORE
03-18-2007 18:08:12
 Re: Correct way to adjust Govenor on JD 303 Gas En in reply to Bob, 03-18-2007 01:34:44
I could only control the serge with the spring alone. I went inside and shimed it to get it closer to the 1500 RPM range. Now at least it only drops no more than 50 RPMs under load but that is better than the 200+ RPMs it did before. I think I would need to change to a different set up to get it perfect. The spring tension is critical to keep it constant! I had to modifi the spring adjustment also after shiming it to a real light pull. Mark H.
Willy-N
03-18-2007 08:05:37
I can see this will be fun to do. I got the Carb/Dist all adjusted great and now it fires off with a tiny bit of choke and a couple turns of the starter. It holds RPM smooth with out load but as the electrical load goes up the RPMs are going down. I am talking about adding 10K or more also and I am loosing around 200-250 RPMs. Mark H.
