39 b noise, ruining my day
kevinjg
03-17-2007 16:09:06
i bought this tractor this winter and i think it hates me.i put a mag on it last night and went out today to fire it up ,started great took it out for a ride and opened it up a little after about 10 minutes a loud metal clanging noise appeared it seems like it is from behind the flywheel and the flywheel has a squeal when i turn it,any ideas what to look for?or has anybody had the same issue?
kevinjg
03-17-2007 16:38:44
 Re: 39 b noise, ruining my day in reply to kevinjg, 03-17-2007 16:09:06
i can feel slop in the flywheel and feel it hitting with the tractor off and i rock the wheel back and forth,i dont know any better way of describing it.
Kurt_JDB
03-17-2007 17:31:38
 Re: 39 b noise, ruining my day in reply to kevinjg, 03-17-2007 16:38:44
Kevin,
Have you checked to see how much end play you have on the crank? Also, do you think the flywheel is loose on the crank?
Kurt
kevinjg
03-17-2007 17:56:42
 Re: 39 b noise, ruining my day in reply to Kurt_JDB, 03-17-2007 17:31:38
i pulled off the oil fill plate and found a worn main bearing now im going through catalogs looking for one
kevinjg
03-17-2007 17:46:51
