Cast iron tub style JD B frame
philip w.
03-17-2007 11:21:34
I just bought a JD B that I plan on restoring that has a frame rail that is one piece cast iron, it is not like the frame on my 46 or 41 B. Were these often used? I cannot read the vin tag, any idea what year this may be?
Rich-WI
03-18-2007 04:34:49
 Re: Cast iron tub style JD B frame in reply to philip w., 03-17-2007 11:21:34
Philip, The cast iron frame was used starting with serial number 136662 until 166999.
jd40an
03-17-2007 13:13:21
If it's a styled B it is a "War tractor". When angle iron became impossible to obtain in 1943& 44, John Deere resorted to using cast iron for the front support. Later when the angle iron became available they went back to steel front supports. Somewhere there is info as to what the serial # breaks on this were. The reason your tag is unreradable, is that it is most likley made of steel, as aluminum was also in short supply.
northeast puller 1
03-17-2007 11:57:40
third party image
Philip this is the tub to my unstiled 1936 B if yours looks like that. I am no sure what year they stated using the angle iron frame. I think when the first styled tractors came out. I no my 1948 A has the stamped frame and full styling which came out in 1948. North East puller
