27 D
chris in nh
03-17-2007 08:12:45
Is there anyone selling early D gasket sets? also looking for front steel, and horizontal twister air stack (repro or good original) thanks Chris
chris in nh
03-20-2007 18:58:39
 Re: 27 D in reply to chris in nh, 03-17-2007 08:12:45
I haven't checked with johnsons yet on prices. I'll put together a list of bolts, my D has a lot of high crowns on it. does this seem odd. I know the later JD's didn't use them. I tried Mc master Carr with no luck, I'll try correct connection. thanks for the help I appreciate it. Chris
Glen in TX
03-17-2007 10:47:34
Did you try your JD dealer yet? Part Details Part Number: AD2674R Part Price: 57.78 USD Gasket Set for Valve, Ring & Cylinder replacement. Part Number: R205190 Replaces Part: D1787R Part Price: 43.34 USD On Hand: 0 Check Other Stores Description: ENGINE CYLINDER HEAD GASKET
Other sets don't show to be available but individual gaskets may be and some are even the same as for the 31-53 D like the head gasket and several others. Many aren't hard to make out yourself out of sheet gasket material with a sharp knife, ball peen hammer and some punches. PC658 is the parts catalog that covers 23-38 D so it will cover early and later gaskets so you can see which are the same and can be had individually by checking at http://jdparts.deere.com . For those gaskets shown not available try Greg Stephens 303-663-5246 [email protected]
chris in nh
03-19-2007 16:49:14
 Re: 27 D in reply to Glen in TX, 03-17-2007 10:47:34
thanks Glen for the help RN Johnson it is I guess, any source for high crown bolts?
Glen in TX
03-19-2007 17:21:49
 Re: 27 D in reply to chris in nh, 03-19-2007 16:49:14
Johnson's didn't have any bolts? Were they less on head gaskets? What size and where do they go on the D ? I may have some from other parted out Ds. Trays full of old bolts for just Ds out in barn. Seems like someone in tractor magazines was advertising some of those bolts a while back? McMaster Carr may or may not have them? mcmaster.com Might check with Correct Connection also.
