JD 5410 Syncro sticks in park
Vincent in Geor
03-17-2007 06:45:22
My JD 5410's transmission (manual tranny, synchronized shift) gets stuck in park ocassionally. Whacking the gear selector gets it un-stuck (so far!) but I'm concerned about causing damage to the shifter linkage as well as the possibility that someday, somewhere it'll be REALLY stuck. I'd appreciate any input as to what may be causing the problem and the best way to fix it....
Vincent in Georgia
03-17-2007 14:50:13
 Re: JD 5410 Syncro sticks in park in reply to Vincent in Georgia, 03-17-2007 06:45:22
Thanks for the information! The serial # is LV5410S342686. Can you provide additional information about the fix?
buickanddeere
03-17-2007 16:49:53
 Re: JD 5410 Syncro sticks in park in reply to Vincent in Georgia, 03-17-2007 14:50:13
Mother Deere keeps an entire parts book online. The major updates were at #351790 on tractors equiped with cabs. Tractors without cabs were updated at #342473. Looks like we should know if your tractor is cab equiped?
Link
Vincent in Georgia
03-17-2007 16:51:36
 Re: JD 5410 Syncro sticks in park in reply to buickanddeere, 03-17-2007 16:49:53
My tractor doesn't have a cab....
WV2cyl
03-17-2007 12:24:43
Both of mine (5400s)were under the serial number and had to be fixed. One was new and the dealer took care of it under warranty, One was a used unit and the recall was never done and the time was up and Deere did not pay for all of it. cost me most of 800 bucks. Also. if the tractors set out much and the PTO is not used frequently, the clutches will stick and have to be broken in middle to loosen them. Second used unit was stuck and we worked on them at the same time of the tranny update.. I now engage the pto several times weekly to avoid more problems on both tractors.
buickanddeere
03-17-2007 12:03:12
What serial number? There is a factory update kit for the 5000 and early 5000 Ten. I'm suprised your dealer didn't tell you.
