1949 R pony motor problem, maybe more...
SonnyDay
03-16-2007 19:23:17
I went and looked at a JD R today. It has been sitting for 5 years in the shed. He said the tractor ran fine when parked, but the pony motor needs to be fixed. I can spin the flywheel on the pony motor, the seller figures that a key needs to be replaced on the shaft.
I'm not fimilar with the pony motors, could that be the case? Is that a tough fix?
The tractor is in decent shape. The tin is good and the tires are 70% with very little cracking. Do you think it's worth $1000? What's the chances of the motor being locked up sitting in the shed for 5 years? Even if it's locked is it worth $1000 for parts?
Thanks for your help.
ram ranch
03-16-2007 22:04:54
 Re: 1949 R pony motor problem, maybe more... in reply to SonnyDay, 03-16-2007 19:23:17
If you can buy a John Deere for under $1000 you'll make your $ back plus intrest, IF IT'S COMPLEAT.(2-CYLINDER)
HenryNC
03-16-2007 20:10:51
I"m very inexperienced on "values" but I"m thinking the "R" is well worth $1000. as long as no major engine problems are evident, and it is complete. If complete, still might be well worth that. Seen a few of the old 2 cylinder diesels start and run OK after many years of under-cover storage. If it is around the southeast....contact me if you are not interested in buying it.
Jim Broughton
03-16-2007 19:56:46
Sonny; Those old "R" JDs were a tough breed and at the time the most powerful JD made !
( Does it have a cab? seems the cab was an "option" back then) If it is in decent shape, and it sounds like it is...ask to have it Towed so you can check the main diesel engine...if it turns over OK, offer him $8-900.00 for it or at least start a negotiation with him. The starting motor will probably have to be pulled for repair, as well as the rest of the tractor checked over for repair/replacement of gaslets /oils fuel and worn hoses etc. $1000.00 if the engine is "free" is not too bad a deal. Hope you got a lot of land to use it on !! Best of luck ! Jim B.
