Ammeter on 4020 Diesel
MaverickM23
03-16-2007 16:58:03
I have a early synchro range 4020 so I have extra places for gauges on the dash. Was thinking of putting an ammeter on it, the tractor is equipped with a generator. According to the FOS manual on Electrical Systems an ammeter would go in the line running from the BAT terminal on the regulator. This line goes on to the top post of the solenoid and then to the negative battery post on one of the batteries. Does that seem like it would work or has anyone put an ammeter on like this? I just like having gauges to monitor everything. I have seem ammeters on gasoline tractors but never diesel so maybe this wont work. Also plan on putting in an oil pressure gauge.
jd40an
03-17-2007 08:52:51
 Re: Ammeter on 4020 Diesel in reply to MaverickM23, 03-16-2007 16:58:03
I installed an oil pressure guage & ammeter in my 4010D many,maybe 40 years ago. I don't remember exactly HOW I did it as it's been so long ago. Jim Guaridino is right, I'm only measuring one side ov the 24 volt system, but it still gives you an idea whether the generator is working. Funny how John Deere set up the dash to have room for these guages, but left them out. Bet the "bean counters" said it cost too much to put them in!!!!! !!
Bob
03-17-2007 06:14:02
Installing and ammeter where you are saying WOULD show the actual output of the generator but NOT the actual gain or loss to the batteries as a conventional ammeter does.
Normally the generator output AND all loads go to one side of the ammeter and the other side does to the battery.
This is the typical setup and shows the actual current flow (gain or loss) to or from the batteries.
Since you really can't set it up that way on the 4020's split 24-Volt system you really can't get it to function as a typical ammeter does.
Jim Guarino, Agri-Service
03-16-2007 19:08:37
If this tractor is still 24 volts, you would need to install 2 ammeters to show a true picture of the electrical system. Since an ammeter only shows current flow, and you have essentially three electrical systems, a single gauge will only be able to show the current flow across one 12 volt leg. If you install a voltmeter, and connect one terminal to the Blue circuit, and one terminal to the Brown circuit, that will give you the resultant voltage in the 24 volt system. It will not show if there is an imbalance between the two 12 volt systems, where one battery is over 12 volts, and the other battery is under 12 volts.
MaverickM23
03-16-2007 20:23:37
 Re: Ammeter on 4020 Diesel in reply to Jim Guarino, Agri-Service, 03-16-2007 19:08:37
When you say across the blue and brown circuits...do you mean across the blue and brown on the regulator which would be the GRD and BAT terminals....or is that across somewhere else?
Thanks for the help
03-17-2007 03:38:58
 Re: Ammeter on 4020 Diesel in reply to MaverickM23, 03-16-2007 20:23:37
The blue (12 volt + gnd circuit) and brown (12 volt - gnd circuit) are connected to the starter solenoid, regulator, lighting circuit breakers, key switch and light switch. You can connect a volt meter between the two "BAT" terminals on the lighting circuit breakers.
MaverickM23
03-17-2007 07:50:45
 Re: Ammeter on 4020 Diesel in reply to Jim Guarino, Agri-Service, 03-17-2007 03:38:58
So a voltmeter between these two wires would show the volts of both batteries, which would mean that I need a voltmeter capable of 24 volts. I take it the negative lead would go in the brown circuit and the positive would be in the blue circuit. I've been looking at voltmeters and they only go up to like 18 volts. Anyone have anything bigger?
Dairy Farmer in WI
03-16-2007 18:19:46
which side of the tach is there a gauge missing? if it's on the right you're missing the fuel gauge, if its on teh left you're missing the temp gauge. just my 2 cents, hope it helps you
DFin WI
MaverickM23
03-16-2007 18:36:29
 Re: Ammeter on 4020 Diesel in reply to Dairy Farmer in WI, 03-16-2007 18:19:46
Im not missing any gauges, I have both the fuel and temp gauges. Since its not a powershift there is no Trans temp or pressure gauge, so there are spots on the panel to drill out more holes for other gauges. I can put two more in, one above and to the right of the fuel and one above and to the left of the temperature. On Powershift these were used for Trans Temp and Trans Pressure. Our 3010 is synchro and there is an oil pressure above and to the right of the fuel.
