1861 thru 1942 equipment identification.........
JDK
03-16-2007 11:16:40
I replied yesterday to a post and want to let everyone know that I may be able to identify some older equipment with some catalogs and original parts price list book that I have. I can't post everything as there are almost 1200 pages of information.
The catalogs have drills, seeders, sowers, cultivators, planters, disk harrows, endgate seeders, horse-drawn stalk cutters, and other old equipment. Some of the earliest drills go back to 1861 and up to 1942. And have lots of serial numbers, years built, production numbers and parts identification numbers. Mainly for John Deere Van Brunt and Mansur Works.
I have some people interested, and want to let everyone else know. If you are curious to find out about some old 'yard art', write me. It would be BEST to have a picture or sketch of the equipment you may be interested in. I will do what I can with whatever info you send me.
Thanks, JDK.
johns48b
03-16-2007 18:21:49
 Re: 1861 thru 1942 equipment identification....... in reply to JDK, 03-16-2007 11:16:40
i have a wheel barrow seeder that was made to sow seed with. it consist of a 13 foot long wooden box about 4 inches square that fit across the handles bars on a wheel barrow that had a drive mechanism that was driven by the wheel as you pushed it along. the drive mechanism would cause a wooden stick running parrell with the wooden box on the outside of the box to move back and forth. this stick had a rope tied to each end of it that ran inside of the box and pushed seed out through a series of holes in the bottom of the box. the box actually has two sets of holes in it, one on each side in the bottom of the box. if you wanted to sow a lot of seed you used the side with a lot of holes in it and there was a strip of wood inside the box that you covered up the other set of holes with that was spaced futher apart to sow less seed with. the box was simply reversed on the handles to drive the stick that pushed the rope in the box depending on the amount of seed to be sown. the drive mechanism had adjustments on it to make the stick move side ways slower or faster. i can't imagine pushing that thing in loose ground and being 13 foot wide and trying to keep it balanced. the only info i found on one similar was dated 1905 and the stick on the outside had been replaced by a gear box mounted in the middle to the box. i don't know how it operated inside. i'd like to know something about the dates this might have been made and who made it please.
